I don't think there's an outdoor power supply at the moment as they recalled the previous batch, presumably with a problem.
I also don't think, even with a fixed power supply, that the camera would continue to work at -25F though continuous power and a silicon skin definitely keeps it warmer
I wouldn't risk it. The outdoor adapter had a specific connection to weather seal it. I think they're rejigging that bit to make sure it's weather-tight. If you run the normal cable for indoor use, you're very likely, especially at low temperatures, to get moisture in the connection and risk a short or, worse, a fire. You've probably already seen the temp rating range is -4F up to 113F but yeah, I wonder if that's limited by battery function
From tests I did a year ago, the camera shuts down at aprox -4 F
doesnt matter if battery is installed or not.
As to battery, it just will not charge below freezing
PS funny thing was the original Arlo cam sitting in the freezer next to it worked fine and also worked fine to -10 F. ( cold as it ever got ) .... Cells did show a voltage sag tho from cold
Operating temperature for Arlo Pro cameras is -4° to 113° F (-20° C to 45° C). For more information, take a look at this article: Are Arlo Pro Wire-Free cameras weatherproof?
For your safety and to avoid permanent damage to your batteries, your batteries do not charge at temperatures below freezing, even if your camera is plugged in. The Arlo Solar Panel also cannot charge your battery at temperatures below freezing. Take a look here: How do I keep my Arlo batteries charged in cold weather?
