Arlo pro in cold weather -16 and colder
  • 6 Replies
  • 2892 Views
Linmar90
I live in Viking Alberta Canada.My arlo pro will not work when it is -16 or colder.is there some thing wrong with my cameras or is this the way they work?
I read that the arlo will work up to -40 i guess that not true.
I have two arlo pro cameras and a base station
when its not cold outside these arlo work great
thanks mark
6 REPLIES 6
The -40C is for the original wireless cameras.  The Pros are stated to work down to -4F/-20C which has been empirically shown to be true.
Think you going to be out of luck....
Specs say bottom temp is -4 ( not -40 )
My tests ( in the freezer ) show that the camera does in fact shut down at aprox -4F +/-.... it will say it must warm up to function.  Temp rises, cam works again
BTW, the original arlo cams that used 4 - 123 cells I've tested to -15 and they stil functioned .  Issue here is at about -20F the battery chemistry starts to fall off and the voltage will sag
Some of the confusion is due to C vs. F. Please be sure to specify the proper system when reporting temps.
Linmar90
i am taking  -16c and colder i live in canada
TEMP Op spec of Pro;
-4° to 113° F (-20° C to 45° C)
PS some cam respond exactly but most are+/- a couple of degrees before shut down
Linmar90
thanks for all the replays
