So i have a specific question about how to set these cameras up, however my guess is someone here already has done this or at least knows how.
I have 4 cameras connected to the same base station. 2 inside and 2 outside. I just set up the 2 outside cameras today. I have used the geofencing mode to turn the cameras to "disarmed" once i got home for the past 6 months with the 2 cameras on the inside. I would like to still use that for the 2 cameras inside, however, i would like the outside ones to stay armed all the time. Can someone explain to me how to do this?
Thank you in advance!!
-Chris
You need to create another mode...
Call it OUTSIDE.
Use ADD A MODE to add the first of the two outside cams, then save .... Add the second camera by EDITING the new mode.
Use ARMED for your Geo AWAY mode and OUTSIDE for your Geo HOME mode
Call it OUTSIDE.
Awesome! Thank you! I figured there was an easy solution I just wasn't sure how to do it. Should be working perfectly now!
