  • 4 Replies
  • 2043 Views
Snoopy12
I have owned my cameras for less than a year. I bought the three year protection plan and have hit dead ends everywhere I turn. My batteries will not charge anymore. Can anyone help? Thanks.
Read this,...  https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Snoopy12
Thanks. This did not work either.
Then you'll need to open a case with support:
As mentioned, the warranty is one yr, so file a report
As to the 3 yr protection plan, is that the store's or Arlo's ( didn't think Arlo had one )... either way for that you'd have to file accordingly
