Arlo pro camera stays black when turned on. Doesn't show image. Have to toggle Night vision.
  • 5 Replies
  • 2125 Views
Duke92
My arlo pro 2 camera doesn't show picture when first turned on. Stays black like the night vision isn't working. I have to toggle it from night vision off/on or take brightness to 100% then back to finally get the picture to show properly. Any ideas on how to fix it?
5 REPLIES 5
Is this happening during daylight, or only when you turn the camera on at night?
Did the camera originally work correctly? Or is this a new installation?
Duke92
Seems to happen at night. The camera is in my garage by the way. Not a new install. Only recently started happening though. Putting the brightness up to 100% then putting it back to 50% seems to make it go back to normal.
Ok.  I'm guessing that the garage isn't lit?  If so, it sounds like NightVision simply isn't kicking in.
Have you tried restarting the camera?
Duke92
Still not resolved.
JessicaP
Hey Duke92,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
