Arlo pro camera senativity issues
My arlo pro night vision detects every little dust particle as motion at night and during the day, also when sun glare on driveway reflects at certian times during the day it also is detected as motion and will record.Only remedy I have come up with is to switch off night vision on that camera ,when off the camera function normally untill sun glare is at the worst angle in day light.Otherwise camera functions as well as the other 2 I have.I have tried playing around with app settings for motion sensitivity nothing seems to work except turning off night vision Help plz.
That's not normal.
Have you tried swapping around cameras, moving one of the others to the position where you are having this problem?
Also, have you made sure that the protective film that came with the cameras has been peeled off?
