Arlo pro Siren
  • 1 Reply
  • 2176 Views
jasoncoau
Hi there, for users that have the Arlo pro base station without the siren (it looks more like a modem) is there an add on option for a siren? like a wireless / wall plug in siren option? otherwise the entire base station would have to be repalced?
With the batteries, are there any rechargeable batteries for these units?
Jason
The Pro base only comes with the siren.  It's the original base that doesn't.  ANd, no, there's no add-on siren although you might be able to work something through IFTTT and/or SmartThings.  If you want the siren, you need the Pro base.
