Arlo pro battery won't charge 1st charge
You can NOT use a normal USB adapter to charge the Pro camera ...it needs the one supplied with it.
It puts out dual voltage at 5 v and 9v to run or charge the pack.
If the battery is an issue, ( if you have two swap it with another camera to test ) the warranty is a year from Netgear Support
Did they fail or did they deplete due to recording and live viewing? Spec life is based on <5 minutes of both per day. WiFi connection quality also can play into this issue.
I don't know if the batteries depleted because when I plugged them in they would not charge and the camera would not turn on. Take the battery out and the camera works fine,
Either swap at the store or open a case with support using the Contact SUpport link at the bottom here.
I had a similiar issue. Plugged the camera in but it wouldn't appear to charge. With the help of tech support, I removed the device, unplugged it without the battery for 2 minutes, plugged it in and then resynched it with the base station. This worked perfectly and the battery then showed that it was charging, the battery was at 99% and the camera would show live video. The only thing that I had to do then was readd the camera to the modes I have setup.
