  • 2 Replies
  • 2906 Views
clawsteal
I have just one Arlo pro camera installed , I will be putting up a few more. It's up very high on my garage so I bought the xtra long charge cable. I see the battery indicator says only 90% and decreasing evety day. Do I need to remove the battery since it is connected to a power source?
No the battery should be fine left installed... the power loss may be due to the long run of thin wire from the ac adapter
Along with a small gauge wire. That's exactly why I recommend only quality cables with larger wires. I search for quick charge ones and compare the wire sizes.
