Arlo pro battery dying after 2 days in my small business
  • 2 Replies
  • 957 Views
Nie5
I am using this for my small business and the battery was dead after 2 days of using it even though the rechargable power line was plugged in all the time.( day and night). There are movement all time during the day but no movement during the night.
Is this Arlo pro not suitable for business with many movement?
brh
@Nie5
If you have access to constant AC power for the Arlo power adapter, you should be able to just remove the battery and run the camera just on AC power.
Are you using the original Power Adapter and cable that came with your camera?
If the camera is in the Armed state all the time how many notifications are you receiving per day?
Or, are you using the camera in Live View constantly?
Brian
When the charger is plugged in properly, the icon for the battery charge should have a lightning bolt through it. Do you see that? There's no reason for a plugged in camera to deplete the battery. Use of an improper charger could be the cause as can a faulty device (camera, cable or charger).
