- 2
![](/skins/images/FF9F1A2D72D38ABCDF776A121A01A9D1/responsive_peak/images/icon_anonymous_message.png)
My Arlo Pro is one week old and now base station is stuck at "getting information" is there a solution for this?
I was successful in reaching Mark Merrill and now have a case open.
"Case Summary: VMB4000 - Executive Escalation "
They are going to be reaching out to me the next business day (which I suspect is tomorrow). I will provide an update if the information given to me proves useful to the community.
Mark Merrill is the CTO (Chief Technology Officer) of Netgear.
https://www.netgear.com/about/management/?cid=wmt_netgear_organic
Our base says 'getting information' And it seems to be stuck there. I have tried rebooting, unplugging everything, factory reset, even a new router....... no luck. We have had this system for 7 months. First problem, and it seems the base is hooped..... please advise. We purchased a security system for a reason. Please advise asap.
Done, thanks!
And thanks again! The support at Arlo were very quick, and solved my problem very quickly!
Jo-Anne wrote:Done, thanks!
If base glitches: (Apr 2017)
- remove (delete) base from app
- with pin or paper clip push reset in back of base for 30 seconds. Light(s) should be amber. Let base reboot for 2-3 minutes. Reload cameras
I was rebooting improperly, this method worked! All working good now.....
I have two of these camera's have had them for less than a week and am currently seeing this very annoying status(Getting status...) that seems to be an ongoing issue with these camera's from what I am reading? Should I be taking these back for my money back?
Regards
Tys_wow,
Consider rebooting the base station using the on-off button. Allow the base to come back online with a solid green power and internet LED and try again. Are you still seeing the same behavior?
- 2
