Anyone know that answer to this question:
"quick question do you know if the base station for the Pro 2 is the same as the base station for the Pro? I’m thinking of getting add on Pro 2 but just wondering if I will be missing missing anything from the Pro 2 base station"
Pretty sure it's the same base. This probably shouldn't be in the Ideas Exchange section 🙂 An add on Pro 2 camera will work with a base from the original Arlo HD, Arlo Pro or Arlo Pro 2 kits
Sorry about the location of the post, but thanks for the information
