  • 2 Replies
  • 1931 Views
Mpan
Is there a way to save videos after the 7 days they are in the cloud? I saved it to my google drive but it won't play now that the 7 cloud days are over?
Downloaded videos will play at any time with a player that handles them properly.  The free VLC works fine as long as you use the latest version. Make sure you download them and don't just grab shared URLs.
If your rummimg the Arlo PRO, jut put a speed stick in the usb slot and enable the backup..
5 GB or more will prob last you months
If your running Arlo, then you would have to upgrade yr service level
