Arlo pro Base station offline
The base station remains offline whenever the router reboots or looses internet connection. I have to restart the base station for the cameras to start working again. The firmware version on the base station is 1.18.10.1_13433. This is really annoying if you are not home and this issue occurs. Has anyone else have issues where base station goes offline due to internet/ router issues?
Not really a fix for your problem but a workaround could be something like a wemo switch (outlet) that you can control with wifi that powers the base station. Then when there's a router reboot, you can manually power off and power on the base station to restart it. You shouldn't have to do this but for now, it's a workaround
This is a good idea as a work around but I hope their engineers are looking for a fix on the base station itself.
