Arlo - pro 4 cameras wire free working for few hours then stop working.
Just installed the cameras got them all to work recording clips of movement 5 to 15 sec movements all camera worked for 6 hours then all stoped working showing the hub box is offline. I've noticed when looking in the device section it shows 4 cameras and the hub base box but it appears to be two hubs I only have one can someone help? I've tried to remove the hub box bit has removed all the cameras.
any suggestions
Try power cycling the base station
steve_t wrote:Try power cycling the base station
Hi Steve I've tried this still doing the same works for 6 hrs then goes offline
I would call support down below here or return/exchange your kit if possible..
