- 2
I agree. It may however be an issue with ports at the ISP level.
wanttofish has tried just about everything. What else do you think it could be?
So where does all this work leave me in regards to what would be the next step?
Can someone post basic steps to open port 80, 123 & 443.
It would be a router configuration. Since you're asking the question, it's unlikely that you need to open those ports since you would have made some security changes in the router so you'd know about these things. The other possibility is that your router is owned and configured by the ISP in which case they have to do the configuration for you.
Are you having issues using the app or a browser on a computer? If the latter, some anti-virus software, such as BitDefender, has caused issues. Tell us more about what you're using.
- 2
