So what is happening.. ? How many cameras do you have ?
As to your issue, if it was only that camera, when removed and brought back, it would have erased itself from any Modes you have and then when brought back been added to the default ARMED mode.
So it may be that you modes got glitched in storage.... Have no idea how, ....but you should not edit the default ARMED mode, but made a custom mode/copy to do editing on.
If above is true, you may have to remove all your cameras and then do a reset of the base ( hold reset on the base for ten secs till the leds flash ) and bring each camera back as new
Take the camera that is recording wrongly, go to settings and use REMOVE DEVICE
Bring the camera back as if new ( resync )... this should solve your problem
Ok i just did that and now the system is acting completely different. Could you please call me...
