Arlo no longer recording same motion as my Ring doorbell
Over the last couple of days, my Arlo camera has stopped picking up as much motion as before (specifically cars driving by). Previously, it picked up the same motion that my Ring doorbell picks up, so I would be covered from different angles. The Ring doorbell is still picking up cars, however Arlo will only pick up people. This is an issue as we have suspicious cars that drive round at night and there is a spate of car crime and break ins.
I have reset the base station twice, removed and re-added the camera, ensured that motion sensitivity is 96%, recording schedule is fine and set to record, push notifications are on. Firmware is up to date.
Can anyone suggest how to resolve this issue?
It is the VMB3010 base station but it won’t let me select that option
The Pro maxs out to about 25 ft for people... for cars it could be reflection of IR for a better distance, changes in the sun angles can easily change response as the seasons change.
You can always recheck and adjust the sense level of the cameras or location
I have increased sensitivity to 98. It used to be on 90 because anything higher would pick up my trees blowing in the wind. Not 98 barely registers unless you walk right in front of it. It registers even less at night.
https://ring.com/share/6665550194122693880
Very frustrating as you can see the transit van is parked just behind my cars in daylight! Previously this would have been picked up but over the last three days nothing. Very concerning. Any ideas on how to resolve?
Hi @vernoncakes,
As TomMac mentions, you may want to try rechecking and readjusting the location of your cameras. You can also try using the motion detection test to make sure motion is detected where your camera is located at: How do I use the motion detection test for my Arlo device?
