Arlo local storage recording sequence is reversed, storage to USB first, then Cloud
  • 1 Reply
  • 1258 Views
jchomley
Having an Arlo Pro system for which I pay a subscription, I would like the feature that the recording sequence is reversed, storage to USB first, then Cloud. IF my internet goes down my system is still functional. This could be enabled with a firmware key on subscription. Netgear still get subscription money, regardless of recording sequence. Maybe offer this feature for thr Pro series for upgrade incentive?
steve_t
Master Master
The cloud and USB recording is simulataneous. In the even that your internet goes down, it will still record to the USB drive. Unfortunately, you have to remove the drive from the base and plug it into a computer to view the recordings
