I uninstalled base and cameras yesterday to reinstall, one camera was having issues. Trying to re-install and Arlo can’t find my base station. I have a single light all blue.
When you reset the hub, you must also remove all devices from Settings, My Devices before you can claim you hub again.
There is nothing showing in settings, zero cameras or base.
Try holding the base reset button until the LED flashes amber. Let it reboot to solid blue (~2 minutes) and try again.
The same thing can’t find it.
Try adding the base using a PC browser (my.arlo.com).
Same thing.
The base station is showing in my networks as Arlo_VMB_4203260@#$
I am having this same issue. Any resolution?
@blhickok
Can you PM me with your admin email contact?
