Any help and advice would be highly appreciated
Finally
This issue where the new app will not link to the VMB3000 base station is now resolved the method of pressing the reset button does not work, you need to use a pin or paper clip and hold the reset until you get amber lights showing. Wait until the base station has two green lights (the first two) then the new app will find and link to the base station, you can then add you cams.
Thx to all that came up with the various suggestions
@sirte wrote:
... they are designed to link to Netgear22 router
There is no Netgear router that is branded as Netgear22. Perhaps you are referring to a network name????
Can you tell us
- the model of the base station if you have one
- the model of the router if it has Arlo built in
You should be able to find the model on a label on the model/base.
Hello StephenB
Yes you are correct I submitted the Network SID
The Netgear Base Station is
Model VMB3000
Serial48E3577AA1DA7
After rebooting the Netgear base station the new app defaults over the old app and requires the Base Station and iPhone on the same network (which it is)
Then discovering the device fails.
I cannot log into the base station directly as it requires a password (which I don’t have)
Any help would be much appreciated
Thanks and regards
Model VMB3000
That just means that this is an Arlo base station for Arlo Wire-Free Smart cameras that dates back to the Netgear era.
Is there a router in front of this thing somewhere?
Unless things were very different back then – these are ageing devices – you don't login into the base station.
Find support for your cameras in the document library here:
Arlo - Security Cameras and Systems
Just another user
You can't log into the base station.
Check the status leds on your base, and see if they report any issue: https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
Also browse to https://my.arlo.com with a PC browser, and and see if it shows your devices.
If they don't, you should contact support: https://www.arlo.com/en-us/support/contact.aspx
@sirte wrote:
VMB3000 not found in the document link
Try a search in this place.
Dozens of hits.
Also try looking for Arlo Wire-Free cameras.
https://www.arlo.com/en-us/images/Documents/Arlo_Wirefree/arlo_wirefree_um.pdf
Just another user
The issue is with the new app
@sirte wrote:
To get This thread thread back on track the issue is that the new app will not link to the VMB3000 base station. The base station works fine and the cams show on the Arlo website.
If the phone is using a different account with guest access, then you will need to re-grant access to that account.
If that's not the issue (or if re-granting doesn't resolve it), then you should contact support. https://www.arlo.com/en-us/support/contact.aspx
No reply from Arlo email support
Which in its self is a pretty poor advert
Not resolved
Not resolved
Not resolved
The iPhone and vmb3000 is on the same Wi Fi
Not resolved
Finally
