  • 2 Replies
  • 1040 Views
knothcd
I have had this system with two camera.  Both cameras work for about 12 to 24 hours then disconnect for 24 hours.  They then will reconnect themselves 24 hours later.  What the hell!  Batteries are at 100% and have full bars on the connection.  This is getting really annoying!  Any help out there would be appreciated.  I already have my Amazon labels printed to send them back.
JessicaP
Hi knothcd,
Have you tried rebooting your Base Station to see if that helps from your Arlo cameras disconnecting frequently?
knothcd
Hi...thanks for your response.  Yes, I have, they seemed to go offline again sometime last evening, just did a remote restart on the base and they came back up.  will see how long this will last.
