  • 2 Replies
  • 1910 Views
Koen1960
I have a basic Arlo set base station with 4x VMC3030 camera's and would like to buy additional the set pro base staion with 2 camera's. So i will have 4 camera's without voice and have 2 seperate base stations.. is this even possbible to realise such a combination?
thanks for the help
All the cameras will work on either base ( tho I recommend the Pro base due to usb backup and siren )... your issue will be running all 6 cameras if you are on the Basic level ( as that limits you to 5 total... not the number of bases )
There is no limit on any number of bases on any account
You can upgrade to the next level ( paid service ) which allows 10 cameras but you also get 30 days storage.
If you don't want to pay, keep one of the older cameras as a backup.
Running two bases is the only true way to expand area coverage.
Koen1960
Thanks for your input -Clear it is..grtz from Belgium
