My arlo app on my iPhone 8 locks up on the opening white screen after I upgrade iOS to 15.0. When I tried to open the app, after asking for allowing notifications, it got stuck on the white screen.
I removed the ap and redownloaded it. Same problem
Ok I finally got it to work after going back and forth between removing, reinstalling and rebooting. Thanks.
Hi watsonlv,
Try uninstalling the Arlo app again, reboot your iPhone 8 and then reinstall the Arlo app again and see if that helps. Also see if you see any difference when trying on cellular data or on WiFi.
I uninstalled the Arlo App. I rebooted my iphone 8. I reinstalled the Arlo App. Still freezes on the white arlo screen. I turned off the cellular data (wifi only). Same issue. I turned on cellular data and turned off my wifi. Same issue.
