Arlo app crashes frequently
LG G6 running Oreo..
Arlo app crashes with a popup notification to close app or provide feedback.
I am using the GEOFENCING mode.
Crashes when I use camera or receive a phone call etc.
Started occuring a month or so back.
Anyone else seeing these issues ?
For over a month now the Arlo app keeps crashing on my SO's LG V30 and my LG V30. I even got a brand new phone and did a clean install and the issue persists. Because the app force closes constantly, geofencing is not working and neither does schedule. The cameras haven't recorded anything on their own in weeks. I send feedback reports every time it FC's.
Yes. I even got a brand new phone and did a fresh install of Arlo without restoring any data.
Anyone seeing this issue on other phones - other than LG ?
This defect only occurs with the Arlo app and only started recently..
@JessicsP it looks like Arlo have changed the title of the original post. Please change it back. How do you know this defect is limited to LG phones on Oreo ? Keep the title generic until it has been isolated please.
Try to update to the latest Arlo app and see if that helps the issue: Arlo Android App - 2.7.0 - 8th January 2019
The persistent notification is annoying but is perhaps a Google issue. Using the notification system to keep track of which apps are active is not intelligent. I now have 3 permanent notifications. It should be configurable.
It looks like this defect is now fixed. No crashes.
Hey @HotdogBottle,
What phone device are you using?
It's an LG-H932 on Android 8.0.0
Try to clear your cache/data for your Arlo app from your Android phone setting and try to log back in to see if that helps.
