Arlo VMS4130-100EUS Pro Camera - Is there a solar panel compatible with the camera?
  • 1 Reply
  • 894 Views
Tony_SA
VMSxxxx is a system sku, not a camera model.  You can find the camera model in two ways:
  1. remove the camera from the housing, and then remove the battery.  You'll find the label inside.
  2. go into the support area of the app, select the camera, and scroll down to the product id field.
Assuming you have an Arlo Pro (VMC4030) or a Pro 2 (VMC4030P), then the appropriate solar panel is the VMA4600:
