Arlo VMS4130-100EUS Pro Camera - Is there a solar panel compatible with the camera?
VMSxxxx is a system sku, not a camera model. You can find the camera model in two ways:
- remove the camera from the housing, and then remove the battery. You'll find the label inside.
- go into the support area of the app, select the camera, and scroll down to the product id field.
Assuming you have an Arlo Pro (VMC4030) or a Pro 2 (VMC4030P), then the appropriate solar panel is the VMA4600:
