Arlo VMC 4030 compatiable with base station VMB 3000???
  • 1 Reply
  • 3026 Views
mannymarques
Is the newer smart camera VMC 4030 compatible with Base VMB 3000???
Will two way voice work??
Streak2
Master Master
Yes it is compatible and voice, which is a function of the camera not the base will work.
You just wont have the siren option.
Streak2
Master Master
