Arlo Solar Panel Waitlist
- 2
Is there a way to get on the waitlist for the arlo solar panel?
Nice to see that it is finally listed on the site. $70 seems pretty steep considering the ring solar panel is $50. I will probably still pick one up though as I have a camera that gets a lot of acivity and needs to be charged every 2 months. Let's hope it is available for purchase soon.
lets hope for a speedy release. The outdoor cable has been coming soon for a few months now, hope the charger doesnt follow
James,
Mid-May has now past. Is there any update to when a solar panel will be available. If it will not be soon, where can we find the exact electrical specs to be able to buy/create/use an alternate solar panel. We are using our camera on the cell phone network and the batterlife is extremely short and changing the battery everyweek is not practical.
Saw this response on their Twitter account.
https://twitter.com/ArloSmartHome/status/869252611412643840
We are looking at a late Q3 (July) for the Solar Panel and Outdoor adapter. Thank you for your patience!
We have a PV Solar Energy Pole with intgrated Li-ion battery for Smartphone charging/topup (Schools, Restaurants, Tertiary ground, off-grid app) LED lighting etc. etc Would like to add the Arlo range to be powered. Does anybody have the power + consumpton specs for all the models? The Arlo GO, would be prioriy. Much appreciated.
The electrical specs from the AC charger that came with the Arlo Go that I just bought says the following:
NETGEAR
AC Adapter
P/N: 332-10966-01
Input: 100-240 AC 50-60Hz 0.5A
Output: 5V DC 2A or 9V DC 2.23A
Model: AD2090320
Type: 007-1LF BAH
Careful with the Arlo solar panels. I installed two brand-new ones 6 days ago. Today, one of the two went bust and it's giving me an error message saying "The charging source connected to the camera cannot charge your battery. Please use an Arlo power adapter." I'm currently jumping through hoops with Arlo support to get a replacement.
Can't you just return it to where you bought it? Don't waste your time with Arlo, just take or send it back to where you bought it.
Thank you for the advice. I think that's what I'll do. I was assuming that I wouldn't be able to return it to Best Buy because I no longer have the box, but I checked and apparently Best Buy accepts returns without the box. I may give that a try this week.
Your first lesson should have been never throw away a box until your sure it's won't be returned. Nice that BB will still take it though.
Just a curios question... how is the official Arlo Solar Panel, rated at 6v output is able to charge the 7v battery of the cameras and the Ring Solar Panel (also at 6v output) was reported several times that it wouldn't work because of the higher voltage required to charge.
Could anybody shed some light into this?
If you're experiencing an issue with the Arlo Solar Panel, be sure to take a look at this article for troubleshooting steps to ensure the panel is positioned and set up correctly: How does the Arlo Solar Panel work?
- 2
