Although no deliverly date set yet, Amazon is now taking orders for the Arlo Solar panel as of today. I ordered two units so at least I'll be in the first group of orders before they sell out. If for some reason Best Buy gets them first I can simply cancel my Amazon order.
Keeping my fingers crossed!
Drake3287,
Thanks for posting.
The Arlo Solar panel should be hitting stores soon, so we've updated some help documentation on it should you have questions out of the box.
Here are some helpful Arlo Solar Panel links below:
Where can I use the Arlo Solar Panel?
How do I position the Arlo Solar Panel to get the most sunlight?
How do I set up the Arlo Solar Panel to power my Arlo Pro Wire-Free or Arlo Go camera?
How does the Arlo Solar Panel work? (formerly called "How can I use the Arlo Solar Panel?")
Although I ordered my 2 Arlo solar panel's from Amazon a few days ago I notice they no longer offer them, even as a pre-order. Wonder if all of us simply ate up the anticipated supply or was it an Amazon mistake from the start? Still no credit card charge from Amazon yet. Time will tell..........
