Will not stay on more than 10 second record. I have gone to mode, armed, pencil and clicked the pencil next to the camera. down to (record video) pencil, and moved the slider to 30 seconds. Have also saved each one. I have tried the back button and also the return on my phone. I have done this for each monitor multiple times and multiple ways and it always goes back to 10 seconds. What am I not doing?
My goof. After I click save, it takes me back to another screen. Then after I click save the second time, it states that it has saved the change. I didn't know I had to click save twice. Thanks all.
Try doing it here.
following the same steps as below. After dragging the slider then back then save.
The go back and check it should still be where you left it.
