Arlo Pro wireless 3 camera - What do I use to attach G6 magnetic mount outside tape, screw, nail?
I have new Arlo Pro Wireless 3 camera unit - What is the best thing to use to mount the G6 magnetics outside? One is going on wood and 2 need to go on the side of the building (stucco)- I rent so trying not to distroy the property. Do I use screw (what type), nail and/or can I use a very strong adhesive. Thanks for your help!
I have the regular Arlo but the same solution should work. I have the magnetic mounts mounted on brick all around my house and have found that outdoor double-sided tape along with a thin line of outdoor waterproof adhesive around the edge works best. The double-sided tape by itself worked fine for six months but then one camera mount fell off and I then decided to add the adhesive around the edge.
For your camera on the wood, you could hammer in a small nail or put in a small screw. I have no idea if that would work though on stucco.
