Arlo Pro with two cameras. Can't change sensitivity
  • 1 Reply
  • 2436 Views
amybourne
I believe there's been an update on the software since the last posts about changing the sensitivity for each camera. I had an Arlo, returned it because it frustrated me, then bought one back deciding I would change the location from outside to inside. Hooked it up last night easily and now am not getting any notifications because I'm assuming my sensitivity is not set high enough. The last Arlo I had a month or so ago, I could find the sensitivity, but cannot now, so there must have been an update changing the location. It's not intuitive.
JPC
Prodigy
Prodigy
Go to "Mode" --> "Armed (Default)" and Click Pencil/Edit on the right --> "Rules" Pick a cam to edit (Pencil/Edit on the right) --> you'll see "Motion is detected" Click Pencil/Edit to adjust  Motion Sensitivity..
