  • 2 Replies
  • 3377 Views
Jhobbs1958
VMC4030 Model
I had to resync this camera twice before for this same issue. Now it will not reconnect at all regardless. Any ideas? Btw, this camera and system is only 5 weeks old. Help!
I would open the battery door, pull pack, then replace.
Go to settings and use REMOVE DEVICE for the camera
Bring the camera back as new ( this will reset the camera and all the base settings for it )
Also swap it with another camera ( location ) to see if issue follows camera
If issue continues, contact Netgear support
Jhobbs1958
Thanks. Did all that already. I guess contacting support is only option. Again, thanks.
