Arlo Pro white solar charger
  • 2 Replies
  • 1582 Views
mullbr
Hi Everyone,
Few quick questions:
Does anyone know of a white solar charger that works with the Arlo Pro cameras?
Can I use another (non Arlo brand) solar charger? If so, what specifications should I look for?
Thanks,
Brian
No white panel TMK, ... also I do believe you are stuck with the Arlo solar panel as the seal for the usb port is a bit different than most ( not to mention the voltage specs are pretty tight ).
Anything else and if water gets in, your on your own as Netgear prob will not warranty with 3rd party items
mullbr
Thanks.. A white panel would be great. Anyone know if that’s in the works?
