Arlo Pro Cameras cannot be activated when being deactive for more than 24 hours
I need help now to activate the cameras.
I have 3 wireless cameras connected to the Arlo Router. Usually they work fine.
Except for when the cameras are inactivated manually for +24 hours.
We are never able to activate the cameras again, only by resetting the Router.
Same problem experienced several times!
But this time the solution doesn't work, we are not able to use the cameras!!
How are you deactivating the cameras? How are you resetting? Have you checked/charged the batteries? What LEDs are are showing what on the base?
