  • 2 Replies
  • 13492 Views
  • 3 Likes
DayDad
Hello,
I just recently bought an Arlo Pro two camera system. I also purchased an Arlo Q. I do like the Arlo Pro system and will be primarily using it for outdoor surveillance. The intention was to use the Arlo Q indoors for the kids. However, speaking from a price point perspective I could get a 4 camera Arlo pro for about $115 more. My question is am I better off going with a 4 camera Pro system or should I stick with the Arlo pro 2 cam system with 1 Arlo Q? Are there any benefits of the Arlo Q over the Pro other than 1080p vs 720p? I'm kind of torn at the moment as to whether or not I should return the 2 cam system and Arlo Q for the 4 cam Arlo Pro pack instead. Keep in mind I only need two cams outside.
Streak2
Master Master
I have also been through this thought process.
Over and above the higher resolution, the nice thing about the Q is that it's externally powered right out of the box and offers 24/7 video monitoring plus optional 24/7 cloud recording.
If you don't need the higher res. and the 24/7 features, but like the external power, then you could remove the battery and still externally power your pros. from an inexpensive USB 5v 1.5A power supply.
The Q has a superior 'sense' method.... It works on pixel change vs the Pro using PIRs
Pixel change is it detects changes from what the camera actually sees.
Other diff is the Q is not outdoor rated.
