Only looking for live view on several cameras of weather conditions at a second home without using motion or recording of info and no alerts. Can this system be set up to do just these simple functions.
Yes, if I understand correctly. You can set the system up and choose the Disarmed mode so the cameras will never detect motion nor record. You can then use live view at any time and manually record if desired.
