Arlo Pro triggers with change in hue every few minutes
  • 1 Reply
  • 677 Views
PhilipF
Pro gets change in hue over top 1/3 of picture, records for eleven seconds and happens every few minutes.
I think you have a hardware issue. Do you have more than one camera? If so, swap them around to see if the issue stays with the camera or location. If it's the camera, you can try removing it from Settings, My Devices and resyncing it to see if that helps. If not, open a case with support:
