No matter what mode I use to activate my Arlo Pro camera system, after a while when I go back and check on it the selected mode is "disarmed"... Being happening the past couple of days...
Read where they said that the situation was fixed but it's not... It's still happening...
Right now, use a browser. The app has display issues. Use of a browser to check and set modes, rules and the schedule works fine. You can use a mobile browser if you set the browser to use the desktop version of the site.
@jguerdat Tried the desktop browser... It did not work... It went right back to disarmed... This is a real security issue... I thought Netgear was better than this... I bought 8 of their cameras... SMH...
Reboot the base. If using a schedule, remove everything and rebuild. Try creating a custom mode and use that.
I'd guess that it's something about the base which is what controls the mode. Your profile on the servers has the info but it's up to the base to act accordingly.
Possible remedies include creating new custom modes, rebuilding the schedule from scratch as well as resetting the whole system and starting fresh.
I did do this: there are several settings: armed, disarm and schedule plus others. I couldn't for the life of me set it to stay armed fire any longer than 30 minutes, and last night I got a brainstorm. Set the timer from 12:01 am to 12:00 pm to be armed. Therefore it is on all the time!
The armed setting is not working any longer.
Thank you.
I might not be understanding.... Sorry!
A new profile would use another email address. It sounds like your profile itself has issues if that is needed and there's nothing you can do to fix it.
The agent I spoke to call it deleting the profile and creating a new one but technically it was deleting the base from my profile, resetting the base back to factory default and re-enrolling the base to my profile... It's just like adding a brand new base to the profile all the old configuration was gone and you have to input your new settings again...
Arlo gave me a fix for the issue...The agent I spoke to call it deleting the profile and creating a new one but technically it was deleting the base from my profile, resetting the base back to factory default and re-enrolling the base to my profile... It's just like adding a brand new base to the profile all the old configuration was gone and you have to input your new settings again...
I was having the same problem and was driving me nuts however i resolved as follows:
1) make sure the cameras firmware is updated.. Cameras need to be charged to do so
Then
2) go into arlo app and go to section where cameras can be armed and disarmed
- make sure armed is selected ( Green circle will be solid to left)
Im sure everyone reading this is saying "I did that already"
Heres the additional step that allowed system to REMAIN ARMED
Now click on the pencil icon to right of armed
- now your cameras will appear ( i have 4)
- one by one click on the pencil for each camera and the functions for that camera will appear such as
"motion is detected"
"audio is detected"
"record a video"
etc
What i did was reselect some functions in order to update then " CLICK DONE"
DO THIS FOR EACH CAMERA
It seemed to update the system and i never had the disarm notice afterwards...
Good luck
David P
