My Arlo has completed stopped working. Neither camera will connect to the base station. I've tried resetting and changing the batteries. Any suggestions?
Contact support? https://www.arlo.com/en-us/support/contact.aspx
If this happened to both cameras at the same time, it's most likely the base station. So if you only restarted the cameras, try resetting the base station too.
