Arlo Pro started to generate countless audio alerts when audio detection is disabled?
Arlo pro camera has recently started generating countless audio alerts even when audio detection is totally disabled IN ALL MODES , microphone is turned off completely, and I’ve tried resetting the camera and base station. Help!!
5 REPLIES 5
Same thing happened to me last week. I had to turn off audio in the Smart settings
Don’t have smart account.
Turn off audio detection in your modes and rules.
I covered that in my original post. Not the issue.
I had a similar issue a couple of weeks ago, though it seems to have gone away now.
You might try enabling audio detection, and then setting the threshold to 1 (minimum value). Then disable it again.
Of course there is also the brute-force option of removing the cameras and base, resetting the base, and adding everything back.
