  • 5 Replies
  • 1700 Views
Lcfire731
Arlo pro camera has recently started generating countless audio alerts even when audio detection is totally disabled IN ALL MODES , microphone is turned off completely, and I’ve tried resetting the camera and base station. Help!!
5 REPLIES 5
JehovasFitness
Luminary
Luminary
Same thing happened to me last week. I had to turn off audio in the Smart settings
Lcfire731
Don’t have smart account.
Turn off audio detection in your modes and rules.
Lcfire731
I covered that in my original post. Not the issue.
I had a similar issue a couple of weeks ago, though it seems to have gone away now.
You might try enabling audio detection, and then setting the threshold to 1 (minimum value).  Then disable it again.
Of course there is also the brute-force option of removing the cameras and base, resetting the base, and adding everything back.
