Arlo Pro recording by sound
  • 4 Replies
  • 8044 Views
SCreading
I just recently installed a new Arlo Pro camera system.  I know it activates by motion.  Does it by chance activate by sound as well?  If so, what is the necessary condition for the camera to begin recording, ie: decibel level, etc.  Thanks.
Yes the PRO does detect and record on sound.... the settings are in the MODE
You can choose Motion, Audio, or both to trigger the recording ...there are also sense levels that you adjust for response
Look up ADD a MODE in the FAQs
SCreading
Thanks.  I'll check it out.
SCreading
I checked out ADD a MODE and reviewed my sound settings.  They are set to max volume.  Is there a way to tell what decibel level is required for the camera to activate and record the sound?  I'm trying to capture excessively loud motorcyclists passing my house.  Thanks.
I would set to loudest and work my way down....
unknown as to Db readings... for that you would need a sound meter and test it with noise given, against the settings, at the camera
As a PS... you not going to get any plates or similar if that's what your needs are
