Arlo Pro rechargeable batteries draining after just a couple of days.
I recharged my batteries 48hours ago and all of them dropped from 100 pct to 50 pct in 24 hours.
Whats going on?
The app is version 2.7.5, not the firmware. The last Pro base firmware update was back in early January and the camera was last updated in mid-October. The app won't affect battery usage but camera and base updates could.
First, exactly what have you tried - all steps? I would start with rebooting the base and reinserting the batteries. Has a new wireless device of any sort been added to the household that may reside near the base? If you use a WiFi analyzer app on your phone and check the signal levels at your base and cameras, does anything pop out that indicates a strong signal maybe interfering with the connection to the base? Your router and base should be roughly the same if the base is near the router.
No, you don't have to pay for support - it's always been free, even after the warranty period.
