  • 6 Replies
  • 9365 Views
nikolayslavov55
Hello,
my question is: what tip of power convertor 220 - 110 V recommend you? Is this one fine? (see attached image).
Thank you in advance
6 REPLIES 6
For the PRO camera, that isn't needed;  It already takes 120 OR 220v input
From the US adapter;
INPUT:100-240v 50/60hz  0.3a
OUTPUT: 5v dc 1.5a or 9v dc 1.1a
nikolayslavov55
Thank you for your answer, but what about base station power ac adapter p/n: 332-10750-01 - input 100-120v - 50-60Hz 0,6A?
Ok, did think you needed as you posted in the Pro section, but...
the US base power supply is 120v input @ .5a  to 12v dc at 1.5a center positive coaxial plug
so the device you show should work fine for it
nikolayslavov55
Thank you very much for your help!
Nikolay
GusRodriguez
Hi!
I am facing the same problem. In my country the current es 220v. It would be great if the base station had a 110-240v imput power adapter as the camera have. Why Netgear chose to support 220v in one appliance and not in the other? So strange.
I have to buy a power converter from 220v to 12v. In the store they ask me whether I need a "switched" or "linear" power converter. Which one should I buy?
Thank you!
Regards,
Gustavo
I'd think either converter would!d be fine with the switched supply being smaller and more efficient.
