Arlo Pro outdoor rated USB cable
I assume that the Alro Pro solar panel will require an outdoor weatherproof rated USB cable to connect to the Arlo Pro. Is there any reason an outdoor rated cable cannot be released at the same time to allow for the Arlo Pro to be used permanently wired in when outside?
This would be a great accessory and make the Arlo Pro exceptionally versatile.
Can you send a link to the solar panel? I didn't see that as part of the release of Arlo Pro.
Hi nictrix this is just one article but there are a lot of others if you google Arlo Pro. It's been mentioned in Netgears press releases and online, but there's nothing on the Arlo site!
http://www.networkworld.com/article/3130210/consumer-electronics/netgear-goes-even-more-flexible-wit...
From the site above:
A solar power charging panel will also be released in early 2017 for users who want to forgo both battery power and electrical power.
