I am looking for an Arlo Pro or Pro 2 camera charging cable that is about 3 foot long but not much longer than that. It doesn't have to be weatherproofed cable but I’ll accept a weatherproofed cable. Any thoughts about where I might find one that length that will charge the Pro or Pro 2 camera?
Theoretically, any USB cable that will fit into the charging port will work. Use a high-quality one rather than the cheapest you can find.
