  • 4302 Views
MontanaDice
Does anyone have Pro or Pro 2 cameras linked to an Ultra basestation?  Since the May firmware update I have been having serious pixelation problems.  Just curious if anyone is using the Ultra basestation and if they are having pixelation too.
I have a Pro , Pro2 and an  Arlo HD hooked into the Ultra base...
I have not seen any difference in switching them back and forth from a 4000 base to the Ultra base.
Of note tho, I did have to move the Ultra base farther away from my main router ; from the 6 ft of supplied cable to about 16 ft of a 20' etherent cable to stop problems with the signal level of the Ultra base .
MontanaDice
Hi @TomMac Are you still experiencing pixelation from the May and June firmware upgrades on your Pro camera/s?
No, ... Over the years it appears the compression used has been increased a bit, which appears to lower the image quality a little...but no real pixelated issues
at least not for a year or so back...it would appear for a short time then go away...
check the " ghosting " term to see if the threads still come up
