Arlo Pro new home setup. VMC4030
Hi.
Having no further use for my Arlo pro cameras.
Have decided to give the system to a family member who is having no success in setting up the system in the new property.
Ive removed all devices before taking them to the new address, and as Arlo suggest try setting up the system using my Mobile device, I was going to set up and then input/edit details as to new email address and a new mobile number, but conatany am presented that no devices can be found.
Any help would be very appreciated.
Best Wishes WME
Hi Shaynes.
No all I done was removed device (base station, & cameras) before removing the whole system and trying to set up in the new property.
So I assume that is still under my account details, & my original IP address hence why its not working as the IP address isn’t recognised/different.
Would I need to contact Arlo to remove me from that system, so it would be installed as a complete new system/device to the new IP at the new address.
Many thanks.
WME
If you in fact went to the Settings > My Devices > Selected the base > Selected Remove Device, than this step was done properly. If you have not, this will affect the new user trying to claim & set up the base station.
Hi Shaynes.
Ive picked up the base station, I will set it up again at its original place my home & try to remove base station hopefully using the correct steps.
I’ll have to see how it go’s.
thanks again.
wme
